The key doesn't work when the steering wheel is locked
13 years 9 months before - 13 years 9 months before #31972 by manual-mecanica
Hi, I have a 2000 Polo 1.9 D and when the steering wheel locks, it's extremely difficult to turn the key again.
It's not the oil, as I recently greased the key and it should work.
What could it be?
Thanks in advance.
Last edition: 13 years 9 months before by .
13 years 9 months before #31973 by manual-mecanica
Manual-mechanics' response on the topic Re: The key doesn't work when the steering wheel is locked
Good afternoon,
it could be that the ignition switch is a little worn and has developed some play. Try moving the steering wheel a little while you try to turn the key.
13 years 9 months before #31975 by manual-mecanica
I already tried that, but it's still running pretty badly. I also tried adding oil. It was parked for 3 months and some moisture got into the car. Could something inside be rusted?
13 years 9 months before #31976 by manual-mecanica
It's quite possible you have some rust. Try putting some WD-40 inside the ignition switch through the key slot, and I think that should fix it
