Problem with the position sensor
13 years 5 months before - 13 years 5 months before #31870 by manual-mecanica
Problem with the position sensor published by Manual-Mecanica
I have a problem with the standard of the position sensor and I do not get the electrical map, it is an automatic neon, mount the connector but I do not find that the emitition car (does not turn on). Please who can help me thanks ...
Latest edition: 13 years 5 months before by .
13 years 5 months before #31873 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with the position sensor
Already scanned the car because you have to be sure that it is a cable when scanar you will realize if it is a cable or the sensor I recommend scanar then tells me that the Sncaner
13 years 5 months before #31874 by manual-mecanica
Eye is not that the code tells me but what the result did the fault code give
13 years 5 months before #31878 by manual-mecanica
Greetings Apaz, when you talk about the position sensor you talk about the sensor of the acceleration body or the one that goes in the automatic box, in case of the box this sensor enables to give "start" to the vehicle since it validates that only in Park or neutral such action is performed, normally to the naked eye it is distinguished by being the two fastest cables in the branch, and in the card the most wide terminals. Without this card, the vehicle cannot be started unless those two cables.
13 years 5 months before #31906 by manual-mecanica
What position sensor do you mean ??? or say where that sensor is located.
When you say that it does not turn on, it is because does it go? Or do the engine run for?
