I have a 306
13 years 8 months before #31746 by manual-mecanica
I have a 306 published by Manual-Mecanica
Hello good it was to see if anyone knows because when I am going out, it jumps the light in the box of the brake of the hand flashing and fixed sometimes and see if someone can put the electric schemes of the car a greeting thank you
13 years 8 months before #31750 by manual-mecanica
Manual-Mecanica Answer on the subject Re: I have a 306
Hi Igor, surely, what happens to you is that you have a false contact on the elèlectric switch of the hand brake lever. The switch is similar to the one we have at the doors that when you open it, the light of the inhabitant is turned on.
Unfortunately you have to disarm the plastic torpedo part where the brake lever is. You have to take out the screws, one on the side of the pedalra, the other on the side of the companion, and the other 2 disarming the ashtray that is seen from the rear seats.
I hope it serves you.
Greetings
13 years 8 months before #31751 by manual-mecanica
voi to look at Avr if that's that hehe thank you very much nobody has all the electrical schemes of 306?
13 years 8 months before #31752 by manual-mecanica
You are in the appropriate pàgina, lower the manual of the workshop of 306, where it shows you absolutely everything you are looking for. You are going to make him more rapid that I sending you the schemes.
Alberto from Buenos Aires
13 years 8 months before #31754 by manual-mecanica
Greetings Igor, check the level of the storage brake fluid, most times this is a low level alarm and use the handbrake indicator. If the level is low, check each hose that reaches the wheels, if you see any as "stained" you found the problem, luck.
