PMS in compression or escape?
13 years 8 months before #31617 by manual-mecanica
PMS in compression or escape? Posted by manual-mecanica
Hello everyone, I have a doubt. When the piston is in PMS how to identify whether it is in your compression or escape career, to differentiate between piston No. 1 and No. 4, since both are found in PMS. I ask this to have the exact location that the distributor's rotor must point, if Bujia No. 1 or No. 4. I know that he must point to the piston that he is in compression race.
Thank you.
13 years 8 months before #31621 by manual-mecanica
Manual-Mecanica response on the Re: PMS in compression or escape?
Hello, look to know in which of the two the spark must jump the sparkus
13 years 8 months before #31625 by manual-mecanica
Thank you for your answer, but it is for when the cylinder head is mounted. I tell you, I step that the distribution system went to the $%&%& it was broken, everything only was saved, and the synchronization 2 admission valves collided with the pistons, so that out everything and I entered the doubt in what I asked since according to the position of the cam of cam gives the 2 options in the distributor. It is a LUV with Isuzu G161 motor. Have a good day.
13 years 8 months before #31627 by manual-mecanica
Cando the two cams point up is in compression but, when the crankshaft are moving for both sides the cams that move, that cylinder is in escape
13 years 8 months before #31629 by manual-mecanica
hi, friend!! As you say that it has brush, to identify the Nom 1 piston in PMS it must point to the aforementioned ...
or if you want to identify it you can turn the crankshaft and verify its admission and escape times
