Mi 2000 Huyndai Elantra does not turn on ... apparently
13 years 8 months before #31577 by manual-mecanica
:( Hello ! I need help to diagnose my car's problem. Apparently it does not turn on the flata of spark
... Leave the car without touching it for a day. The next day he turns to the first .... He handled him three more days but gave me problems when he turned to the march and it took a lock as the second or third attempt. On the fourth day I didn't work for 4 times and I didn't want to download the battery. I leave it two days without touching ... to the fourth turn to the first and leave it on for half an hour ... I turn it off that day the next day the expensive turn on the first one but lasts a minute on and zas ... it goes out ... and after that moment no longer turns on.
Change the ignition module ... which is the terminal where the spark plug cables are connected as well as the equivalent of the distributor ..
Check all the fuses and apparently are in good condition.
Change air and gas filter.
We review the gasoline pump and if it works ........
We check if the cable gave the pump to the pump and if it has a current ........
Check the time band and it seems to be intact ...
we used the ignition fluid that is used in spray and adds by the air filter duct .....
I cannot solve the problem .... Someone could give some suggestions that to make the right problem to be diagnosed
