Hydraulic address problems in Ford Fiesta
13 years 8 months before #31536 by manual-mecanica
Hydraulic address problems in Ford Fiesta published by Manual-Mecanica
Good evening I hope you can give me your opinion, I have a 2004 party that the hydraulic oil is returned by the deposit when it turns off, but they repaired the liqueger tube or oil pump and I think they left the smallest step. Do you think that is the cause? Thanks in advance
13 years 8 months before #31539 by manual-mecanica
Manual-Mecanica Response on the Re: Hydraulic Address Problems in Ford Fiesta
Hello friend how can what you say or have a small obstruction with a particle when it was repaired
13 years 8 months before #31548 by manual-mecanica
Ok, thanks for answering. I keep cheating, I'm going to change the hose and try it as soon as the problem is solved, I warn you that it was
13 years 8 months before #31733 by manual-mecanica
problem solved, it was the tube they welded was obstructed. Thanks for your help
13 years 8 months before #31744 by manual-mecanica
ok greetings from Venezuela
