consultation
13 years 8 months before #31518 by manual-mecanica
Consultation published by Manual-Mecanica
Tark knows how the steering wheel of a Corsa is taken, I have to change, I need an extractor for that?
13 years 8 months before #31521 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
Good afternoon I spliced ​​if you have Air Bag first
that small screws through the back,
then take out the lid in front since it is released disconnects the cables and loosen the central nut, do not take it out of the whole strip of the acia steering wheel
up and with a hammer you hit the nut The steering wheel you can leave the nut and the steering wheel. If you do not carry air. A pressure and you find the nut is the same procedure.
13 years 8 months before #31522 by manual-mecanica
How do I remove the plastic does not have airbag but is conical with stretch marks and gamita, how do I take the steering wheel?
13 years 8 months before #31523 by manual-mecanica
Take out the nut and put it back 2 or 3 threads strips of the steering wheel with your left hand Rara and someone who helps you throw from the other side of the steering wheel also
fur when you are pulling hard, with your right hand it co -injured the hammer and you give a dry blow to the nut I tell you that you put the nut so as not to damage the thread. and it already comes out easily. The new one does not need to hit the nut already pretend well. Note: Be sure to have the straight direction so that the new steering wheel is well straight.
13 years 8 months before #31533 by manual-mecanica
Ok thank you very much, I want to ask I have to change the gearbox to El Corsa Mio is 2005 1.6 and they want to sell me one for model 1.4 of the new 2010 or 2011 Does the relationship of the box change, it serves me or not for mine? Or does it matter is anyone the same?
