I need help
13 years 8 months before #31461 by manual-mecanica
I need help posted by manual-mecanica
Hello, very good to all.
I have a Daewoo Lanos that I bought second -hand, when they gave it to me I had a failure and that is that the hot air that the crital does not work. Nothing came out. Like the rest of the heating if I worked then I let it pass without more but yesterday my heating was spoiled. Only cold air comes out! Ice cream ...
I have read that it may be plugged, the water pump discard it that I have new and reviewed ... so I don't.
If someone can tell me something useful I would appreciate it ... and if there is any manual to disassemble the dashboard also
thanks
13 years 8 months before #31468 by manual-mecanica
Manual-Mecanica Response on the subject Re: I need help
You must clean the hoses that bring the hot water from the engine to the heating radiator, since according to you are a used vehicle and can be capped. and at the same time verify that you get hot water otherwise verify the operation of the engine that drives the air.
