Remove Damper
13 years 6 months before #31424 by manual-mecanica
withdraw Damper published by Manual-Mecanica
Hello everyone, if you can help me, someone remembers the Peugeot Diesel 1.9 engine, to remove the Damper from the tip of the crankshaft. The screw that squeezes it, so that it loosens thank you very much is in a partner 98
13 years 6 months before #31486 by manual-mecanica
Manual-Mecanica Answer on the Re: Remove Damper
Hello, I would like to know so that you need to remove the pulley, Nesecitas change the synchronization band, look I am not sure if you need to change the band and the configuration of your engine is more or less to if you remove the 4 bolts No. 8, to by the way to disagree
13 years 6 months before #31487 by manual-mecanica
If your engine has the following configuration, you can perform the procedures that I told you
13 years 6 months before #31488 by manual-mecanica
If your engine has the following configuration, you can perform the procedures that I told you, suck the image
13 years 6 months before #31516 by manual-mecanica
Hi Fox 30 I am very grateful for your help, look I have problems with the water pump and I need to change it, and the distribution belt change. The Damper that I have is not disarmable, if or if I have to remove the screw from the medium. You tell me that it is is left, because I am going to try loosening to the right, then I tell you thank you very much, greetings
