My Kia Sportage is accelerating on its own
13 years 10 months before #31294 by manual-mecanica
My Kia Sportage accelerates on its own. Posted by manual-mecanica
I have a 1998 Kia Sportage, manual transmission, gasoline engine. About a week ago, it started revving on its own when it's in neutral and when I shift gears (it revs up to 1800 RPM). I changed the spark plugs, air filter, and fuel filter, but there was no change; it's still revving on its own. This is annoying while driving and causes me to use more fuel because I have to wait in long traffic to get home and constantly stop and shift gears.
I hope you can help me solve this problem. Thanks.
13 years 10 months before #31309 by manual-mecanica
Manual-mechanics' response on the topic Re: My Kia Sportage accelerates on its own
I recommend you do that, or have the stepper motor cleaned step by step; carbon buildup causes similar problems... or replace it.
13 years 10 months before #31324 by manual-mecanica
I'm going to follow your advice to clean the stepper motor and see if it works, then I'll let you know how it went.
13 years 10 months before #31325 by manual-mecanica
Check the vacuum hoses that run from the intake gallery to the carbon filter; sometimes a leak or breakage causes the engine to rev up. Check the throttle cable adjustment
