Cavalier 2.4 Year 1996
13 years 10 months before #31278 by manual-mecanica
Cavalier 2.4 Year 1996 Published by Manual-Mecanica
Someone tell me how to put Chevrolet Cavalier 2.4 year 1996 double cam
13 years 10 months before #31281 by manual-mecanica
Manual-Mecanica Response on the Re: Cavalier 2.4 year 1996
Hi Sony, I advise you to change the full new distribution kit and check my photos that I have the chain's time since you have put it the crankshaft about 4 or 16 turns and check that the brands remain the same, if everything is fine, arm it all and check any questions you had
13 years 10 months before #31340 by manual-mecanica
Thank you, it served me a lot, it no longer launches the combustion by multiple admission and I am ready ... but now it does not start that is, but it is as if the injunctors stop working in the fourth motor turn, it does it every time that I start .. This check -in -laws, defeaty pump, new ignition module, new camshaft sensor new, and running if you have any well -come. That helped me a lot ... Safe and blessings
13 years 10 months before #31378 by manual-mecanica
Czech compression is not going to be that the first time is bad time and bend Valves Checalo and you let me know
13 years 9 months before #31847 by manual-mecanica
Hello old .. indeed there was a bent valve and I change it and the ignition I have the bad coils of my car just sparkles two spark plugs 2-3 so to commission the coils and to try .. I warn you how I am doing ok and thanks again
