Refrigerant and overheating VWPARATI
13 years 9 months before - 13 years 9 months before #31215 by manual-mecanica
VWPARATI cooling and reheating loss published by Manual-Mecanica
_Hola Friends, I have a VW Parathi 1.8 2001 Ruedo a few kilometers and is a rod blow in the engine, when I stop I see that he has consumed all the refrigerant and is overheated despite the fact that it marks well its temperature (90 degrees) and the electro fan is worked perfectly, I have tried stop and notice that the refrigerant boots by the releasing of the deposit of the same Electro, I have purged the system and nothing, I have changed the lid of the deposit and nothing, I have taken the mangary of the return and the water is coming (I suppose it is sending the water pump), I have thought it is the thermostat. I need help since I am in a rural area of ​​the coast of my country, where there are no mechanics and I would have to pass a mountain to get to the most next city, thank you.
Last edition: 13 years 9 months before by .
13 years 8 months before #31402 by manual-mecanica
Manual-Mecanica Response on the Re: Refrigerant Loss and Vwparathi Rehelling
Good! It is almost certain is the Board of the Curate. According to how it burns, the antifreeze passes inside the combustion camera and that will be the piston that you hear, so the antifreeze is consumed. Listen carefully when you accelerate the engine and the best you hear like an rrrruuuu that the antifreeze is bubbleing because it is communicated with the cylinders. Other times when the joint is burned, oil and water are mixed, check the oil level in case, which is not higher than normal and does not have a light brown color. Greetings and luck !!
13 years 8 months before #31420 by manual-mecanica
Remove the thermostat, fill the water strip. Arrange the engine with the engine lid removed, keep water until it is already full
... luck
