Kangoo Instrumental Electrical Circuit
13 years 9 months before #31119 by manual-mecanica
Kangoo Instrumental Electrical Circuit published by Manual-Mecanica
Hello, I needing the electrical circuit of the instrumental of the Renaul Kangoo 1.6 I have a problem with the fuel marker and the electrical and floating pump assembly is new but I do not have the values ​​to see with which voltage works and the floating one comes out 3 cables and to be continuity the board is appreciated if you can give me a hand
13 years 9 months before #31158 by manual-mecanica
Manual-Mecanica Response on the Re: Kangoo Instrumental Electrical Circuit
Hello friend regularly the problem is not in the line but in the internal circuit of the float inside the pump you have to remove the pump to check that the poles of the float agan good contact in the circuit sometimes they are separated and stop marking
well I hope I help you and pus the voltage manages depending on the fuel level varies in trep
13 years 9 months before #31162 by manual-mecanica
Hello, your report is appreciated, I tell you the floating one is the complete set and it is fine because it provides it with the tester, in the file I have 5 pins 2 of the pump and 3 of the floating one one mass the other nothing and the last one gives me 3, 4v
