Escort 16V 1.8 regulates very low
13 years 9 months before #31111 by manual-mecanica
Escort 16V 1.8 regulates very low published by Manual-Mecanica
Hello, I have a 16V 1.8 escort in cold, it does not regulate in gasol
13 years 9 months before #31120 by manual-mecanica
Manual-Mecanica Response on the Re: Escort 16v 1.8 regulates very low
Hello, did you check the idle regulator (step by step)
Does the gas system have emulators?
13 years 9 months before #31121 by manual-mecanica
Hello, I imagine that the engine in question is the Zetec with Ford EEC4 injection.
These engines running with CNG usually have difficulty being regulated.
Much more when they accuse some wear, especially in the valve train, but there is a small trick, first check that the advance variator is correct and it works well. If this is so you can try to regulate the iac (or idle) valvular Regulator, with a fine screwdriver you toured it and one direction and the other with the engine running until you find the idle better.
It is usually achieved stabilized the march well but in some cases not.
13 years 9 months before #31123 by manual-mecanica
Hello, how are you already mefix and tell you thanks for answering
