Lumina oil pump problem
13 years 9 months before #31039 by manual-mecanica
Lumina oil pump problem published by manual-mecanica
My problem is to find a diagram where I indicate the position of the oil pump of a Chevrolet Lumina Motor 2.5 of favor someone will have a diagram that can provide me with the appreciation of the thanks I will be grateful
13 years 9 months before #31047 by manual-mecanica
Manual-Mecanica response on the Re: problem with light oil pump
What problem I pay brother to help you
13 years 9 months before #31059 by manual-mecanica
They are usually mounted in the distribution either a pinion dragged by the belt or behind the attack piñon of the crankshaft.
13 years 9 months before #31060 by manual-mecanica
I forget I remember to take out the carter to be able to get the sucker.
13 years 9 months before #31143 by manual-mecanica
Sorry my problem is due to the position in which the rockers with which you have a favor do if they have a 2.5 Chevrolet Lumina engine diagram to verify in which position they must go to these balances
