My Sebring has problems with heating
13 years 9 months before #30977 by manual-mecanica
My Sebring has problems with the heating published by Manual-Mecanica
Hello guys I would like some help with this problem,
I have a 2004 Sebring and the problem is that the heating does not heat how it should, that is, I put it to the maximum and only something a little warm comes out and I am now living in Canada will understand that heating is important.
It occurs to me that if I change the thermostat this should be fixed if anyone knows the solution to my problem please help me thanks in advance
greet you a new member of this forum waiting for help
13 years 9 months before #30991 by manual-mecanica
Manual-Mecanica response on the Re: my Sebring has problems with heating
Ola Cabasa The primer POSO ADAR is to canviar the thermostat then berify if the passage babble is opening complete miRefiero wing Balbula that takes the passage of water Asia the insertiol or heating console
13 years 9 months before #31024 by manual-mecanica
The thermostat?, in the only way that could affect the heating the thermostat is that it is not open, but even so it is almost nothing that this affects on the other hand.
13 years 9 months before #31189 by manual-mecanica
ok friends thanks for your help equal I will start by changing the ¨Blower Motor Resistor¨ so that the power selector that goes from 1 to 4 is working well because now it works only in 4 and then to the other they passed thanks thanks ;)
