Sensors
13 years 9 months before #30967 by manual-mecanica
Sensors Published by Manual-Mecanica
Good afternoon, friends I need to locate the MAF sensor and the MAP in a Peugeot 307 year 2008 has a mileage of 132000 and thanks for your aids again ..
13 years 9 months before #31031 by manual-mecanica
Manual-Mecanica Response on the Re: Sensors
Friend or you have one or you have the other, but they do not assemble together their function is the same for the computer, the MAP measures the obsolete precion in the admission multiple and the MAF measures the air flow that enters the engine, anyway in the MAP they are put in the air inlet hose to the multiple of admission the one that swallows the filter, and the MAF is hosted somewhere To the chassis with two 10 mm nuts carry a hose that reaches the multiple of admission
13 years 9 months before #31036 by manual-mecanica
Ok, thanks Kikomec, for clarifying these doubts, I will locate some of the two to see if I can clean them, when I do it, I tell you. thank you..
13 years 9 months before #31040 by manual-mecanica
Corlection Friend ...
Kikemec wrote: Friend or you have one or you have the other, but the two are not mounted together for their function is the same for the computer, the MAP measures the obsolete precion in the admission multiple and the MAF measures the air flow that enters the engine, anyway in the [Strike] Map [/Strike ] maf Biene of the filter, and the [Strike] maf [/strike] Map is hosted somewhere over the multiple bonnets to the chassis with two 10 mm nuts carry a hose that reaches the admission multiple
13 years 9 months before #31063 by manual-mecanica
Sorry transpires it, the writing is appreciated the correction Jesus, thank you.
