Help in bearing 206 year 205 hatchback
13 years 9 months before #30959 by manual-mecanica
Help in bearing 206 year 205 hatchback posted by manual-mecanica
Hello friends, I am from Chile and I have a 206 all well, but with a headache already because of the wheels, I change rear dough bearing and striker and hard a week, now a boured side sounds on my conductive side, I also spend that I came at speed and when braking when I reached a cross of I stop the car, I spent 2 or 3 times, the first time I have a 206 help please ...
13 years 9 months before #31035 by manual-mecanica
Manual-Mecanica Response on the Re: Help in bearing 206 year 205 hatchback
The pounding is usually the connecting rods of the bewill bar, usually, or vandeja or shock absorber, but the most common thing is the connecting rod, if the thing I do not spend anymore left it like this, if it returns it could be the fault of the very low release, if so you will have to clean the admission body.
13 years 9 months before #31041 by manual-mecanica
Thank you for the help, I thank you, look in part was related to Vieleta, we revived everything and was ok, we released the old woman and try it and the poured was a lot, so we reached the bushings or rubber of the stabilizer bar that were spent, change both side and 0 problems ... with respect to that it stops, they told me that it was a problem in the 206 I feel a crunch when walking or stopping at the back, will be brake balats ???
