My astra g does not want to start
13 years 9 months before #30947 by manual-mecanica
My Astra G does not want to start published by Manual-Mecanica
Hello, see if you can help me, I have an astra g of 99, to which the water pump was gone, the distribution changed, and ready, I stay well, when I went to the start I do not turn on, so I went to the injection pump, which Gasoil arrives, the return also, however to the non -seasoned injectors it comes to him and the car turns on, but when he cools again, they tell me again. The damage is of the injection pump and that I can change it to a mechanic, since the one it has is electronically, or that electronic pump has some way of fixing economics, thanks for the help
13 years 9 months before #30951 by manual-mecanica
Manual-Mecanica Answer on the Retra G theme does not want to start
The bomb has no cheap arrangement since the electronic ones have bad milks to also look at the gasoil pressure distributor. You have to look also the diesel warmeators, if the warmers do not work the non -scoring engine in cold conditions or it costs a lot to start but first verifies the shootings (the warmers can be checked by demonting them and connecting them to a car battery if they put themselves in red live function and if they do not attempt they do not work and have to change them).
