2005 Renault Clio Injector Problem
13 years 9 months before #30938 by manual-mecanica
2005 Renault Clio Injector Problem published by Manual-Mecanica
Good I have a Renault Clio 1.2 of gasoline from the year 2005, I have put the computer and tell me that I have a breakdown in the 2nd injector but I do not know how to change it since I understand that the injectors must be made a regulation according to the injection pump (at least in the diesel) someone could please indicate if it is so, or if I can buy the injector and change it and change it since injection and they tell me that they don't touch gas injection
thanks
13 years 9 months before #30940 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Renault Clio Injector
Hello, the vehicle injectors to gasoline are not regulated, you just have to change it; But it would be good if you try, before making the change, that the wiring is in conditions not to spend money unnecessarily.
Luck!
13 years 9 months before #30942 by manual-mecanica
Hi, I have a 2005 Corsa I would like to know how I can get the board I have to change it. And I don't know how I can get it
13 years 9 months before #30985 by manual-mecanica
Thank you very much Lugerza I will check the wiring to see if the wiring signal is good to see what happens
