Mercedes Vito 110 CDI No Araca Saeft Error
13 years 9 months before #30800 by manual-mecanica
Mercedes Vito 110 CDI No Araca Saeft Error Published by Manual-Mecanica
Hello first mind forgive for the inconvenience.
Teno a mercedes vito 110 cdi of 2002 and did not scour Contact and the Aranque engine or mentions to scratch only a delete relate that oil clik and on the screen of the Ceunta Kilometers it puts Saeft error Sebe a cut poko and there is no way to scratch it that can be the failure.
Thank you
13 years 9 months before #30810 by manual-mecanica
Manual-Mecanica Answer on the Re: Mercedes Vito 110 CDI No Araca Saeft Error
Someone can make me a porfaBorrrr cable
13 years 9 months before #30811 by manual-mecanica
When that message appears on the screen (Display) indicates, that you are not recognizing the CR (main computers) or when you put a key that does not correspond to the vehicle, check with the duplico of the key if it does the same.
If you connected the battery poles inverted or made a short when installing the new battery, you probably have a problem in the CR.
13 years 9 months before #30817 by manual-mecanica
: Ohmy: It seems to me that you burned the black box
13 years 9 months before - 13 years 9 months before #30821 by manual-mecanica
Well of a detail that I remember I do not think that this short circuit because the last bez that plows the van with some scheches Anco arrived home remove my battery well and leave the car approximately the car without drummer about 3 hours and I went to put the new one but no longer scratched and put the error in the displease the new battery place it well. Therefore my question can be the error because the car stays without battery for 3 hours,
I have also tried another key that is original from Mercedes and nothing is the same
Last edition: 13 years 9 months before by .
