Malibu Mod.1998 rear brake problem
13 years 9 months before #30740 by manual-mecanica
Malibu Mod.1998 rear brake problem published by Manual-Mecanica
The problem is that my son stayed without brakes since one of the tap brakes (rear) is thrown away when one of the tires was done from their place of (piston) the balatas were very worn even the drum My question is to serve the piston or I have to change it I appreciate your attention to my problem waiting for your opinion in this regard God bless you.
13 years 9 months before #30743 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Malibu Mod.1998
If the bells are very rectified, the tapes must be overmed, that is, the component that Rozo on the bells (ferodo) must be of greater thickness so that the piston is not disarmed; Even when rectifying the bells are with a different radius to the original radius of the tapes.
