a lot of smoke when starting cold
13 years 9 months before #30997 by manual-mecanica
Manual-Mecanica Response on the Re: a lot of smoke when starting in cold
What year is your vehicle? Can you scananar? It could be the coolant temperature sensor ...
13 years 9 months before #31002 by manual-mecanica
Remember that these engines work by precion in the cylinders, when smoke leaves it means in my opinion that the diesel comes out raw without burning, it is always better to start with the simplest, and verify the level of engine oil, if you have a lot of consumption we are already talking about something else.
all the best
13 years 9 months before #31011 by manual-mecanica
Change heater and check the pump if you have any gasoil loss also check the sleeve that is going to have if you are throwing some oil the turbo and the engine is burning it. Revise the sleeves that go to the turbo.
13 years 9 months before #31018 by manual-mecanica
Friends start at the beginning, what chloro is the smoke that comes out? BLUGE BLUE BLUE?
