a lot of smoke when starting cold
13 years 9 months before #30668 by manual-mecanica
a lot of smoke when starting in cold published by Manual-Mecanica
Hello, I have a Peugeot Expert 1.9TD 92CV that when starting in cold made a lot of smoke and the engine does not rotate round goes to trompicones, something curious that I have noticed is that being in a place that I usually go to more than 1000 meters high, it still starts worse and more smoke still, as you walk and take temperature the engine is already well, then it is very good, then it is very good, then it is very good.
thank you so much
13 years 9 months before #30716 by manual-mecanica
Manual-Mecanica Response on the Re: a lot of smoke when starting in cold
Hello,
the first thing you should do is check the heaters, it is easy for some to be molten.
All the best
13 years 9 months before #30717 by manual-mecanica
Verify seals in valves, it may be that oil through the valve stamps on the head, greetings
13 years 9 months before #30722 by manual-mecanica
It can be injection pump problem or injectors
13 years 9 months before #30994 by manual-mecanica
Hi, it starts with the easiest, new air filter and new heaters see if it improves
greetings
