Problems with Chevrolet Aveo year 2010
13 years 9 months before #30547 by manual-mecanica
Problems with Chevrolet Aveo Year 2010 Published by Manual-Mecanica
Hello friends of this forum, I would like your opinions of this problem that I have, the engine starts normal without problems works 4 minutes and the chek the board appeared and it was sent to scan ,,,,,,, Circuit of the sensor heater02 ... Sensor bank 02 that code which argues the scora please I await your answers I will appreciate it.
13 years 9 months before #30549 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Chevrolet Aveo year 2010
Good afternoon friend, the code that has thrown the scanner, deals with the heater of the oxygen sensor, to verify:
-Combreba the resistance of the heater, two cables of the same color in the oxygen sensor.
-If you have resistance, which is around 6 and 20 ohm, check if you have +30 or positive contact in one of the heater cables.
-If you have it verifies that by putting contact, by the other heater cable in grounds through a multimeter, there is indeed land for a few seconds.
I hope it helps you
13 years 9 months before #30551 by manual-mecanica
Media with the tester in continuous voltage and a pair of clicks and fix how the voltage varies! Paste a couple of accelerated and fix if it varies constant or not? If it does not vary constant, it may be that the Lamda probe is failed and you will have to change it!
13 years 9 months before #30586 by manual-mecanica
Thank you for your help my dear friends .... The code is thrown by the Scaner is: PO141 The same reading of the previous one mandates it and the new appeared the day sigte but I try 2 cables the same color one of them varies but the other is maintained in 12.13 volts and again the chek appears and how I can do it to solve the problem.
13 years 9 months before #30587 by manual-mecanica
My friend; To solve your problem you just have to change the oxygen sensor and then reset the failure. It is common in the Aveo that fails that sensor. :lol:
