Chevrolet Aveo braking problem.
13 years 11 months before #30419 by manual-mecanica
Chevrolet Aveo braking problem. Posted by manual-mecanica
I'm having a problem with the brakes. When I press the brake pedal, there's a noise like something is dragging, and the ABS light comes on intermittently. If anyone has a solution or any help whatsoever, it would be greatly appreciated. Thanks for your time.
13 years 11 months before #30429 by manual-mecanica
Manual-mechanics response on the topic Re: Chevrolet Aveo braking problem.
The first thing to check is the brake pads and shoes; depending on the noise level, you may be missing pads or shoes. If either fails, the ABS will not compensate and will register the problem.
13 years 11 months before #30439 by manual-mecanica
Change the brake pads. The light that comes on is due to a sensor on the pads that activates when there's no more material left, hence the noise (metal on metal). Best regards
