Consult Problem Changes Nissan March 2012
13 years 9 months before #30337 by manual-mecanica
Consult Problem Changes Nissan March 2012 Published by Manual-Mecanica
Good,
I recently bought a 2012 March, with manual box, is my first car. Today I was driving normal, and suddenly when starting at a traffic light in 1st it did not go from 20km/h, and began to jump, then passed to 2nd, the same thing happened as at 40km/h, and in 3rd no, but felt without strength. What I did was stop and turn off the car for a moment, I started again and worked normally. I would like to know what happened, what could be the cause, and if it is necessary to bring it to review or wait for something similar to occur.
Thank you
13 years 9 months before #30338 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation Problem Nissan March 2012
It may be that instead of the first place the third unintentionally passes, on occasions it passes and the symptom is the same, with the new vehicles the marches are very together and if it is your first vehicle you want you committed this brother, but you would have to wait for the failure to make the failure again before taking it to the mechanic since they will charge you and if the fault is not difficult for them to find it, as a advice leave it so.
13 years 4 months before #35453 by manual-mecanica
Hello, I tell you that today the same thing happened to me. On Monday I enter the workshop to look at it .... Does the problem continue? Did they resolve it? ... or did you not present yourself again?
13 years 4 months before #35538 by manual-mecanica
Good night,
the problem did not present me again, at the moment it happened simply, I turned off the car as for 1 minute and I turned on it normal and already. I have worked perfect for me: Laugh:
greetings
13 years 4 months before #35541 by manual-mecanica
Good! Thanks ... since yesterday I entered the specialized workshop and this week will answer me. I tell you the problem and told them that I expected a coherent answer since it is a car taken 1 month ago from the concessionaire and has no more than 300 km tours.
I will keep them aware of their response. Greetings!
