Motor does not start
13 years 9 months before #30361 by manual-mecanica
Manual-Mecanica response on the Re: Motor does not start
Greetings Mg, try this, pass the key but do not get ready, now with some screwdriver test activate the starting donkey solenoid directly, if it starts your problem can be in the switchera of the key, possibly when it is starting it removes the current to the ECU and obviously it does not detect that the engine is starting. You have noticed that in some air conditioning vehicles do not even light the blower when the engine is off even with the key to start, it is an electromechanical measure to not put a load at the time of starting, I hope it helps you, luck.
13 years 9 months before #30366 by manual-mecanica
Solved.
Thank you friend Wolfi77, you were all right the problem was in the contact sheet. I did the test that you told me and the engine was launched without any problem and to make sure I disconnect the coil and realized that when giving the key the feeding of the ignition coil is cut, thank you very much for your help
13 years 9 months before #30369 by manual-mecanica
At the order here, I see that you verified the lack of food by starting, good procedure and thinking. Most of the switches remove the current of the accessories when starting, leaving only the active ECU, but with the use it wears out and what happened to you happens. Well you know that in this forum you have people interest in solving incognites and problems. Greetings.
