Motor does not start
13 years 9 months before #30334 by manual-mecanica
Motor does not start published by Manual-Mecanica
Hello friends, I have a ignition problem with a Volkswagen Vento year 95 Multi EFI injection, and it does not reach spark plugs, what tests I must do to discard components, for your help thank you very much
13 years 9 months before #30339 by manual-mecanica
Manual-Mecanica response on the Re: Motor does not start
The first thing to Checar is the captor of crankshaft or magnet captor, of course it seems to me that your vehicle if I do not remember it, it takes it inside the distributor, it is a disk that rotates and the accountant of it is the one that fails, it should be noted that the coil is also one of the main suspects, check that comes to the coil and if it comes to it but it does not cut the signal for the spark Occasions These distributors get wet and bother until they dry. That to eat.
13 years 9 months before #30354 by manual-mecanica
Hello friend Kikemec, what I could check just a few minutes ago is that the car by pushing, starts and remains in idle, and when stopping it and giving it part with the key it does not start and if I push it again if. Do you think that data helps something? thank you
13 years 9 months before #30356 by manual-mecanica
Hello, then at the time of being the car stopped and starting, the engine turns? Does the starting donkey work?
Greetings!
13 years 9 months before #30359 by manual-mecanica
If the engine revolves without a problem, just that sparks does not reach the spark plug, but when pushing it part
