White smoke
13 years 9 months before #30289 by manual-mecanica
Manual-Mecanica Answer on the Re: White Smoke
Well friend I greet I am going to talk very clearly that when you do that kind of work you have to do the bench to the camera I explain you change bench shell and connecting rod 2nd the camera in that enters guide And he will see that his problem will be solved
13 years 9 months before #30292 by manual-mecanica
Hello. Here I make my contribution I hope it helps:
the consumption of oil can be given in the following parts:
1. segments or rings spent by the time of use or by applying additives that promise to repair the loss of compression but what they do is paste the rings and worsen the consumption of oil
2. By stamps and guides of the valve
3. By the PCV valve. Sometimes we do not pay attention to it but she is a cause of this consumption and can complicate us when she does not take
it into account:
Measure compressions of each cylinder and compare with manufacturer's specification.
If there are low compressions, use the leak test to verify the percentage of losses and through the blowing air to pressure that is supplied for this test determine the point where it is if it is if.
If these preubes pass them without problems, then you have problems with the PCV valve that is mounted on the upper engine cover or valve cover as we know it here. Greetings and I hope it helps you
13 years 9 months before #30295 by manual-mecanica
I will take your observations a thousand thanks
13 years 9 months before #30297 by manual-mecanica
It happens more often than you think since improving the compression of the cylinder head
