INSTRUMENT TABLE OPLE VECTRA Z1.9DT
13 years 5 months before #30249 by manual-mecanica
PROBLEM INSTRUMENT TABLE OPEL Vectra Z1.9DT Published by Manual-Mecanica
Hello, I am Julio, I have an Opel Vectra of 2005 and the failure it has is in the instrument box, no watch or any light works, a while ago I failed several times but stopped the engine and started it again and worked well but now it has stopped working at all. have if you can help me, thanks a greeting
13 years 1 month before #34587 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Instrument Table Opel Vectra Z1.9DT
Hello.
Could you tell me if you already solved this problem? I say it because I have the same car of the same year and the same thing just happened to me. I have proven the fuses of both the interior habitaculus and those of the trunk and some mark continuity but many others are not correctly.
If you can help me, I will thank you, I'm somewhat worried
Greetings and thanks
Note: My email is
13 years 1 month before #34597 by manual-mecanica
Try the relays, it is possible that some have been spoiled and not of the passage to the fuses by cutting the circuit and giving ruling of the fuses.
Another option is to dismant
13 years 1 month before #34625 by manual-mecanica
Account well reviewing food cables, now so that they can find the fault, they will have to disassemble quite and very uncomfortable but you can accrue cable continuity until they find the point where they are cut.
13 years 1 month before #34634 by manual-mecanica
Thank you very much to both. Do you know where I can locate the electric schemes for this car)
