Daewoo ignition I wait 1994 A/T 1500cc Iny
13 years 9 months before #30350 by manual-mecanica
Manual-Mecanica Answer on the Re: Light of Daewoo I wait 1994 A/T 1500cc Iny
Hello good morning, the sensors that you have to check are the ones that correspond to the box, if you turn on the car you will manually manually manage It passes current and gives the Power fault and does not make the changes automatically but I have to do them manually. I hope you can solve
13 years 8 months before #31763 by manual-mecanica
Well, for all the opinions that have given me, I replaced all the important sensors, MAP, Mat, TPS, O2, Mimimo Regulatory Valve, Refrigerant Temp sensor, the electric gasoline pump in the electric, the spark plugs, high tension cables, ignition coil and the distributor, check the computer, the alternator and start all under control, now the car turns on, but once the car is set To turn on, that happens when it spends a lot of time off, check the emptiness hoses, now when I turn it on, I fuck a lot Car in its original state, it is barely the beginning now with the wiring and the box, then I will comment ..... B)
