Meriva heating problems
13 years 9 months before #30157 by manual-mecanica
Meriva heating problems published by Manual-Mecanica
Greetings MDM Community, I have problems with my 2005 Meriva, of heating the radiator fan turned on very slowly changed the module and temperature sensor, to the radiator recovery does not c heat, I already changed water pump, remove thermostat, and brushed their heads and continues to do the same the same is heated the F on the board and turns off the cool that cools it again. What else can I do?
13 years 9 months before #30186 by manual-mecanica
Manual-Mecanica response on the Re: Meriva heating problems
If it turns slowly, try it directly to the battery and see how it turns, you want here is the problem in the internal or enfoinated resistance of it.
13 years 9 months before #30252 by manual-mecanica
Thanks for your comment, already check that and it's fine from the fan
