Injector cleaning
13 years 10 months before #30066 by manual-mecanica
Injector cleaning by Manual-Mecanica
Good, maybe someone helps me, occupy knowing marks and types of liquids that are used in cleaning gasoline injectors, these to be used with buoy.
13 years 10 months before #30077 by manual-mecanica
Manual-Mecanica Response on the Re: Injector Cleaning
Dear colleague, there are many products in the market to clean injectors with buoy, such as Würth and Wynn's. What you should know is that if the vehicle is modern, p. eg. With two lambda or oxygen probes, one before and one after the catalyst, it can happen that during cleaning with the buoy, the light of the Chek Engine of the instrument board is turned on because the Lambda probe or oxygen sensor does not detect a good combustion. To turn off that capable light that you have to resort to an official service of the brand so that by means of the appropriate scanner the light (a thousand) or of contamination warning. In those cases it is best to disassemble the injectors and clean them by ultrasound. LUCK HECAN.
13 years 9 months before #30131 by manual-mecanica
I fully agree that the best way to clean injectors is with ultra sound, it is the best to be able to clean without causing damage and a better cleaning.
