Toyota 2kd
13 years 11 months before #30062 by manual-mecanica
Toyota 2KD published by Manual-Mecanica
: S Hello, I need to consult a problem that is being presented with a Toyota 2KD the problem is as follows, in the morning the truck does not turn on, but if it is in PUJA, turn on and does not bother the whole day until the next morning, I already changed the preheating spark plugs, I clean the capture sensors, the rail, check the injectors, and do not record any code in the board, if someone can help me this It's my email .. thank you....
13 years 11 months before #30078 by manual-mecanica
Manual-Mecanica Answer on the Re: Toyota 2kd
Dear colleague, first of all you must ensure that the engine has good compression, if it is low compression and if you consume oil it may cost to start cold. It would even be good to know the real mileage and travel of the vehicle.
Second, it is important that the start rotates fast and that the battery voltage is not less than 10.5 volts during the operation of the starter engine. When you push it to start it, it is important to know if you do it too much smoke by the escape and in that case what color is. LUCK, HECAN
13 years 11 months before #30105 by manual-mecanica
Viejo, HECAN Note something in the truck in the morning before turning it on, I gave him bombin in the fuel filter, and normally turns on the filter is new and does not show leaks and does not discharge, he has 150,000 km and does not consume oil, nor does he present smoke or black or white, I think that it can be the injection pump that is to take out hand .. If you have any idea you let me know a hug.
13 years 11 months before #30120 by manual-mecanica
Hello, you can place a transparent pipe after the fuel filter to control if air appears in the line with the cold engine and if air appears to control that the inlet connector to the fuel filter does not have dirt. Luck !!
13 years 11 months before #30121 by manual-mecanica
If you give the bombin and part without any problem then the oil of the pump and the oil line is downloaded.
