Citroen Saxo problem
13 years 10 months before #29900 by manual-mecanica
Citroen saxo problem published by Manual-Mecanica
Hello good, I have a Citroen sax, with the crosy camshaft, the air system changed x the admission bell, reduced butt to increase pressure, Iraes 4 in 1 collectors and OMP exhaust pipe They go, if they could help me ... I think the problem comes from. thank you so much
A coordial greeting! And happy new year!
13 years 10 months before #29921 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem Citroen Saxo
Hello but you have released you from the coil connector
13 years 10 months before #29925 by manual-mecanica
Kee goes, the problem is the two cables have been broken below, and I can't know where Ivan, and the mechanics here are all scammers and do not soon mechanics, they are replenishing parts; I like the issue of mechanics and I prefer to do it, they leave the coil and do not where they are going to stop, there are about 10 cm. of cable and then they are loose, just where they spliced ​​have broken ...
a health and thanks for everything
13 years 10 months before #29995 by manual-mecanica
What fails you? Describe Maas!
