Disconnect transmission differential pallier
13 years 10 months before #29868 by manual-mecanica
Disconnect Transmission Differential Palier published by Manual-Mecanica
Hello good I want to take a mechanical box, and I already took the shield on one side of the differential, the one on the other side does not come out, I have not wanted
13 years 10 months before #29875 by manual-mecanica
Manual-Mecanica Response on the Re: Disconnect Transmission Differential Palier
Well, if you managed to get one fix at the end that goes inwards, you must have insurance at the tip of the axis, it's like a ring. This insurance is embedded in a slot that has provided the stick ... It is usually enough to pull the axis to remove it. If you already release the bolts that support the wheel mace .. I hope my answer serves you .. Anyway get a wooden deck to hit it ...
13 years 10 months before #29880 by manual-mecanica
The box side is pulling and nothing else, if it does not come out you make a small lever between the palier and the box and nothing from the other world, if what you cannot take out is the homocinetic tip of the wheel side of the dough striatum, give it a few blows with a hammer but put a stick so that you do not damage it is not complicated either.
