Balo derefrigerant level
13 years 11 months before #29858 by manual-mecanica
Balo derefrigerant level published by Manual-Mecanica
Good afternoon I tell you, I have a problem with my 2001 silvery, it always appears on the screen that has a low level of refrigerant and I review and it is well level the question is the following how I can eliminate that function or correct that problem I thank you from beforehand your help "open some way to bridge (by-pass) the sensor"
13 years 11 months before #29861 by manual-mecanica
Manual-Mecanica response on the Re: Balo derefrigerante level
Greetings Gerardo, it is possible to bridge the sensor more not recommended, check first if the sensor is "stuck" or broken inside, if I am not mistaken it is a kind of float that when being at the optimal level it is kept above closing a magnetic contact, when stuck or broken it remains low. It must be three cables, right now I do not remember the colors to bridge but you can rehearse with a bulb or test tip and use it as a bridge, test and warn us how it went. Greetings
13 years 11 months before #29883 by manual-mecanica
It is correct what Wolfi77 says is not advisable
