Ford Galaxy 97 is heated
13 years 10 months before #29825 by manual-mecanica
Ford Galaxy 97 is heated by Manual-Mecanica
I have a Ford Galaxy of 97 1.9 TDI I have changed thermostat, 2 sensors that it carries in the refrigeration circuit, all the sleeves and the radiator sensor but it heats up and the fan does not jump (if I make the bridge to the radiator sensor if the ventiladsor jumps) that may be hot to the maximum having refrigerant liquid
13 years 10 months before #29842 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Galaxy 97 is heated
If you make the bridge to the radiator sensor, the most cause is that it is since the sirwy works correctly for what you say, that sensor that you say is the temperature bulb?
13 years 10 months before #29919 by manual-mecanica
That radiator bulb is new
13 years 10 months before #29920 by manual-mecanica
Hello friend, what the fellow Kikemec tells you all the reason if you bridge and it is that the failure is there if I recommend that you observe if the obstructed radiator is not and of course that the circuit is well bleeding if everything is well recommended that you buy the temperature acorn of origin of origin because I have had more than a problem with acorns cite.
