Changes in Vortec.
13 years 10 months before #29824 by manual-mecanica
Changes in Vortec. Posted by manual-mecanica
Hello, who could I tell me, if the injury of injection could be changed to an admission with carburetor ??? ,,, and the electronic distributor for a simpler one with platinum? ' and cancel the computer ??? I want algae that can fix ... thanks : Ohmy:
13 years 10 months before #29835 by manual-mecanica
Manual-Mecanica response on the Re: changes in Vortec.
If you can only have to make some modifications in the CAMARIN to place one that is TBI or carburado and the distribution works the same only as if you are looking for a good mechanic does it if I settled that I work here in Venezuela and they are not difficult
13 years 10 months before #29838 by manual-mecanica
It is true is nothing from the other world, this modification can be done, I have done it in Alfa Romeo and in deep and have not given any problem.
13 years 10 months before #29856 by manual-mecanica
Thank you fried for your answer, I think I understand that, what I should change, is the aluminum tapestry where the air is taken and the accelerator cable? And everything inside, like the spider and injectors them ??? I apologize I do not know the name of the engine parts, please detail them by their shape, I would believe that there is the same piece of admission, but with the carburetor seat. because I saw other vortec v6 with carburetor ..:) thanks for the support in the idea,
13 years 10 months before #29857 by manual-mecanica
Thank you friend, the truth that I have doubts about how to make the reform, what pieces move to change or modify? and seen other vortec v6 with factory carburetor, and would you think should only change the aluminum piece of the admission? Because I have the admission lid where the air enters and has the accelerator, and inside it has the spider and its injectors, do you think you also have to replace the piece where the injectors have positions ????? Well friend I hope you understand me. Thanks for your advice .. : Cheer:
