Centralized closure xsara 2
13 years 10 months before #29700 by manual-mecanica
Centralized Closing Xsara 2 Published by Manual-Mecanica
Hello people, I need help with the centralized closure of my Xsara 2, which when I pulse the control to close only closes sometimes, what it usually does is close and then it is reopened again, that is, the same as it does when you do not close a door well, but I assure myself well that they are closed, what can happen and how to solve it?, To all effects thank you very much and happy parties and new year.
13 years 10 months before #29708 by manual-mecanica
Manual-Mecanica Response on the Re: Centralized Closing Xsara 2
I recommend checking the adjustment of the closure with main control, that is to say the closure of the door that commands everything, on the occasion the door of the driver and the co -pilot, they are main controls if you lower the latch are low Normally, it serves as an idea for the last, luck and happy holidays for you too.
13 years 10 months before #29860 by manual-mecanica
Hi Kikemec, thank you very much for the help, I have checked it and the problem is not solved, but I thank you as if that had been the solution, happy new year personally and at least, until next time ...
13 years 10 months before #29863 by manual-mecanica
Greetings Cra_77, check if your vehicle is like some Fiat that use the "closure" sensor in the lock mechanism as such, that is, the mechanism that closes the door against the "hook" of the body, usually happens that with the use it is loosen and resulting as a consequence that sometimes the door closed as it does not solenoid), try to close the mechanism with the hand and see whether or not the sensor is activated, it is usually a switche or as we call it here end of the race, tell us how it went. Greetings
13 years 10 months before #30020 by manual-mecanica
Thank you Wolfi77 I will keep your advice as gold in a cloth for when I fail again because it turns out that mysteriously has been repaired alone, now there is the muskery that lasts ... hehehehe, I hope that the kings are brought to you many things, a greeting.
