Fiat Pointsx windows
13 years 10 months before #29675 by manual-mecanica
Cortalunas Fiat Pointsx published by Manual-Mecanica
Good
I have a fiat point 60 SX with electric windows but these have a hard time climbing, you have to help them, I remember that a long time ago disassembled the upholstery of doors and clean the gums where they go up and down but nothing, and I am.
Someone knows if this is something classic on these models.
thank you
13 years 10 months before #29680 by manual-mecanica
Manual-Mecanica Answer on the Re: Equalunas Fiat Pointsx
It is something classic in all the levalons, usually, the engines are broken or they lack land or already of old people need change.
13 years 10 months before #29690 by manual-mecanica
Or do they lack land? What do you mean the grounding that is bad?
13 years 10 months before #29710 by manual-mecanica
Over time, the vehicle lands emphasize to deteriorate since most of these are cables that are attached to the chassis or the same engine by means of eyes and bolts and how they are on the interjar oxidize or dirty and make a bad connection have it. Depending on the alsas engines, they can be the problem of coals and things like that, clear those are a bit old, but if you fail all the alsas, the most caused thing is that it is a bad common land of the circuit, you can measure current to rule out that it is little voltage if you want.
