Injecting codes
13 years 7 months before #29582 by manual-mecanica
Injecting codes published by Manual-Mecanica
Hello friends, I want to make a query if you would know how to tell me, the XSARA PICASO year injectors year 2001 Gasoil Motor with Common Pump Rail are encoded with the ECU?
THANK YOU
13 years 7 months before #29585 by manual-mecanica
Manual-Mecanica Response on the Re: injector codes
Greetings Mondanza, so far I do not know vehicles where the injectors are "electronically" with the ECU, obviously each engine has a type of injector in the appearance of the injected volume, and electrically the impedance of the same, which if there is ecus that measure the impedance of the injector and if it is the range (more than all those of low impedance or "peak and hold") of error, as well as when the injector circuit is opened. What problem do you have?
13 years 7 months before #29586 by manual-mecanica
Hello friend, the Bosh Credi system if you have coding with the ECU since if you install them so you will not take time ago I was doing my practice in Gildemeister Hyundai and Terracan service and all the CRDIs had to put the hi scan to be able to install these injectors and how your citroen brings that system I imagine that it should be the same I do not know if with the lexia 3 Take it where they have the scanner to install your injectors that are not cheap to burn them so much and do not waste your money
13 years 7 months before #29587 by manual-mecanica
Greetings, you never stop learning in this automotive science, hehe, it is good to know that of coded diesel injectors, I imagine that they will soon go to gasoline, I would not be surprised that one day of these does not want to start your vehicle because the spare rubber is from another vehicle .. hehe .. greetings!
13 years 7 months before #29589 by manual-mecanica
Good afternoon I have touched those engines quite a lot and regardless of whether Bosch or Siemens are not carrying any coding. Otherwise they carry a screenwriting on the electronic head together with the injector ref
