The air of my corsa does not work ..
13 years 10 months before #29463 by manual-mecanica
The air of my corsa does not work .. published by Manual-Mecanica
Hello .. I tell you that my problem is as follows: I have a Corsa Wind Mod 2000 acquired 2 months ago has an original air and worked perfectly until yesterday .. today I turn it on and it works 15 to 20 seconds and cut the 5 or 10 seconds come back on and so on and so on
what could it be?
13 years 10 months before #29467 by manual-mecanica
Manual-Mecanica response on the re: the air of my corsa does not work ..
Well friend first you have to check if the electro turns on secondly verifies if a suiche sounds under the glove compartment that turns on and turns off if it sounds like that in the dehydrating filter there is a valve with four cables verifies that not this sulfatado then you tell me how it went
13 years 10 months before #29471 by manual-mecanica
Well friend check the system load if it is very low
and if it is fine, then check the compressor clo coil. EDUARDO MIRANNDA TECHNICAL AIR AUTOMOTIVE AIR.
13 years 10 months before #29484 by manual-mecanica
Step 1.- Checar If the temperature control selector is in maximum (blue).
Step 2.- Checar Freon pressures (operation in operation, by technician or qualified workshop)
Sucion 30 PSI Download 180 - 200,
if the pressures are lower the operation of compressor for lack of Freon.
Step 3.- Check the condenser fan
by not activated raises pressures and prisoners short the operation of the compressor as a system protection measure.
13 years 10 months before #29576 by manual-mecanica
Very good comments and understandable. I AGREE.
