Clutch and speed box of Seat Cordoba 100
13 years 10 months before #29558 by manual-mecanica
Manual-Mecanica Response on the Re: clutch and speed box of Seat Cordoba 100
Galguitos, thanks for helping me, if I try to supplement at first with a series of washers, they are telling you that it provisionally gave me a good orientation from where to start looking for problems and if everything was worn out for that reason I began to change pieces like crazy, that yes, it was not easy for me, until now, so far the problem, thank you very much for interested investing in all new, thank you !!!!!!!!!! ;)
13 years 10 months before #29562 by manual-mecanica
Chabon is the box that enhances from behind by means of a long rod that passes through the center of the pilot axis to the press, which is inversely commissioned the pole and the vent Or you look at it in detail you will realize that you take off and skip your teeth and do not push it and now, it's like a large commaq and the center is teeth.
13 years 10 months before #29563 by manual-mecanica
Kikemec, thanks for answering me, I already changed that piece that as you say it is a why, they change it a new one, it is more of plastic and it breaks just by looking at it, but that theme I already solved it and follow the subject, now I was thinking of changing the pedaling bomb again, it seems to me that it does not act with enough force, thank you very much for your contribution and for answering me !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ;)
13 years 10 months before #29581 by manual-mecanica
CHABON When you changed it, you left it in the correct position, because it does not bring any position brand but it goes in one, because if it does not work it does not work I will take out that part to give it the position hahahaha I had more than Chato Jajajaja
13 years 10 months before #29620 by manual-mecanica
Hello again Chavo Look, when you put the first with the engine stopped and leave the clutch torn and then you start it throws the car wanting to move forward?
