Clutch and speed box of Seat Cordoba 100
13 years 10 months before #29456 by manual-mecanica
Clutch and speed box of Seat Cordoba 100 published by Manual-Mecanica
Hello, I have problems with the clutch of the velocity box of a Seat Cordoba 1.6 100cv model 2000, change the two clutch pumps, the rush the back of the rear seat and even the plate and the disc are perfect, but do not upload the pedal until the top and do not enter well the changes, as if it lacks clut Winning from this box, thank you in advance !!!!!!!!!!!
13 years 10 months before #29485 by manual-mecanica
Manual-Mecanica Response on the Re: clutch and speed box of Seat Cordoba 100
Good, I think you must first verify that you do not have air in the circuit, remove the air of the circuit loading the liquid from the clutch bombin up, and then tests. The pieces you have put are new truth?
13 years 10 months before #29488 by manual-mecanica
All the exhibits are new and original of Seat or Wolswagen, according to specifications of the SEAT catalog, try to car all the possible air of the sircuito, I did it to the old while my friend pumped and pressed the clutch, I with the 10 mm plabe would have and took out the air, purged very well but in this way, I do not have an empty pump to do it, but I believe that the theme of the air Fresolvi, the same will continue to deal with there, I am, something I doubt, but you always have to leave the doors, thank you, for your help and for approaching this topic. ;-))
13 years 10 months before #29489 by manual-mecanica
If you replaced the pump slave, you must verify the length of the embolo.
13 years 10 months before #29503 by manual-mecanica
Orienting me, from where I regulate it?
