Renault 5 1300 cc pointer calibration
13 years 10 months before #29450 by manual-mecanica
Renault 5 1300 cc pointer calibration published by Manual-Mecanica
Hello good night, I have problems with the calibration of the edge of a result 5, 1300 cc. In what order should be calibrate? At what temperature (hot or cold), the opening should be .15mm for load and .20 mm for exhaust?. Thanks for your help.
13 years 10 months before #29565 by manual-mecanica
Manual-Mecanica Response on the Re: Calibration of Renault 5 1300 CC
Hello friend, the calibration is so you must do it with the cold engine since the pieces are dilated and there will be good ways to do it and the simplest is that of Cruce you do that the two valves of one of the cylinders in singleopo (footsteps) are left and then calibrates the one that crosses it for example: we put the cylinder number 1 then we take the cylinder number 1. Cylinder number 4 after 4 to 1 from 3 to 2 and 2 to 3
