3y motor problem
13 years 10 months before #29375 by manual-mecanica
Motor problem 3y posted by manual-mecanica
GOOD I HAVE A PLACH WITH A TOYOTA TRUCK INJECT WITH 3 AND THE PROBLEM IS THAT THEY DOES NOT START TO DOCK THE ONLY THE ONLY FORM THAT IS STARTING THE EARTH OF THE INJECTORS ONE ONLY THEY BURNING THE APPROVALS FOR A MUCH I WILL THANK THEM!
13 years 10 months before #29382 by manual-mecanica
Manual-Mecanica Answer on the Re: Motor problem 3y
You do not specify the car model, but I would recommend that you check the cold starting injector, which is not open due to poor function or cold starting sensor failure. Another point to be reviewed is the free operation of the air flow the aircraft
13 years 10 months before #29383 by manual-mecanica
If it is benchin, I check the state of the injectors if it drown it is for a bad mescla, either by a lot of benzine or by little air, this has thousands of factors to check, the first if your check Engine is turned on or off, if it is then turned off air, if you are on you have a scanner.
13 years 10 months before #29422 by manual-mecanica
Thank you for your help and model is 85 and the cold ingestor is closed does not inject and disconnect or connect to the censor and equal any idea that you could give me would help me a lot thanks again thanks again
13 years 10 months before #29423 by manual-mecanica
Ok, the engine only starts while the injectors are disconnected, we can assume that they are land, the Main rely gives+ to the injector but he gives it the computer.
