Chevrolet Aveo, accelerates alone
13 years 9 months before #29446 by manual-mecanica
Manual-Mecanica response on the Re: Chevrolet Aveo, accelerates alone
VALVULA IAC ATASCADA CHANGE
13 years 9 months before #29449 by manual-mecanica
Hello,
the problem of acceleration of the bird is very common this damage is detected very easy with the Scanner Tech2 but if you do not have these they are the most common points,
-IV VALVULA stuck, but I see that they already renpass it.
-TPS outside the Rangon 0.6 V This is identified very easy, when it is accelerated and the caught car disconnects the TPS and you connect it again if the car decelerates can happen two things. That the TPS is bad or that the connector pins are open look at the pins and if they are open, and finally disconnect the computer harnes and clean it with electronic cleaner you let it dry and connect it.
13 years 9 months before #29470 by manual-mecanica
Hello friend, tell me where I find the connector to the computer, and if anyone has e, thanksL Aveo workshop manual ls 2004
13 years 9 months before #29490 by manual-mecanica
The valve already changed it, clean acceleration unit
13 years 5 months before #34212 by manual-mecanica
Hello, how, I have a 2007 Aveo with the same problem, it accelerates cold or hot, sometimes if sometimes not, the IAC valve (for generic and original) is changed as four times, the cable that allows the passage of the air and the injectors were cleaned, I have taken it where 3 mechanics (including the one of the Chevrolet) and nothing, is fixed for a few weeks and returns again to accelerate in minimal Take it, I have thought it is the computer, help me please
