consultation
13 years 10 months before #29363 by manual-mecanica
Consultation published by Manual-Mecanica
Hello, how are you wanting to know the fork and clutch pedal parameters of a Hilux Totoya truck. and what are the minimum and maximum measures.
13 years 10 months before #29380 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
Good night. This diagram is for the European models Kun .., GGN .., LN .., TGN .., I hope that for American models it also serves. Greetings from Spain.
13 years 10 months before #29385 by manual-mecanica
What is the fault that the truck requires, in reality most of the technical data are in laboratory conditions and with all new, but they will serve as a parameter, if you tell me what failure you have we can help you better
13 years 10 months before #29395 by manual-mecanica
The truth is that I have the problem with wear with a clutch disk but they want to make a technical report with measures of parameters Pedal race. Bombin, and clutch fork. We need to dismantle gearbox. Only support with measures. thank you
